Yes, fault output pins are almost always open-drain just because of this reason: you often want to save pins and ease routing by treating all faults equally, without needing to know where the fault is coming from. This is especially handy if your fault handling is a discrete logic circuitry and not an MCU, you don't then need a large OR gate.
Just remember the pull-up resistor or it won't work!
