I'm a programmer/systems architect by education and by the way of conduct, but somewhat 3 years ago I've got an electronics bug - had a sidejob to fix a LED board, got into microcontrollers, then made myself comfortable in analog.
Several times in his videos Dave told - go on, make a product. So i've made one - even probably built "down to a price" at some extent.
It's a "plant watering alarm" - you set the dry point, then water the plant and then it starts to chirp when the plant dries out, rare chirps at the beginning and more frequently when the water level really goes down. It has an LED hooked up as a light sensor, so it does not make noise when it's dark.
I've used capacitive sensing technique where square wave is fed into RC filter formed by known resistance and unknown capacitance as a wide track on the board. Filtered waveform is triangle-like. It is half wave rectified by a diode and stored into a capacitor that has a bleeder resistor. When the capacitance changes, the peaks of the waveform become lower or higher.
I'm feeding 1MHz from internal rc oscillator of attiny44 micro. I've measured my sensor to be around 4.3pf - 75pf, used the same board to measure this, so i might be a bit off. I've put some effort to calculate and measure the most optimal filter resistor value, so I get the widest range and then I looked for the shape of the sensor so it gives me more range. I decided against opamp as I was building this down to a price ,) The range I got is 508 - 833 LSB which is pretty enough for the application. Now I see that maybe by adding a full bridge rectifier I might gain more.
http://wemakethings.net/2012/09/26/capacitance_measurement/The isolation from moisture part was a bitch - water seeps in almost thru any stuff eventually. The combination I've found to work pretty ok was a scotch tape and some varnish designed for electronics. Epoxy works too, but lowers the range and the thing is not really designed to be covered in it.
The great and ineresting challenge to extend the battery life. I've set myself a goal of 1year on a cr2032 battery and learned many tricks how to get current consumption down - slowing down CPU speed when not measuring, sleeping all the time with only watchdog running, turning off every peripheral that is not used at that moment, etc - this was real fun.
Regarding manufacturing - waiting for orders from china, screwing up with gerbers and playing mail ping pong between western new year and chinese new year - man, what can I say - this stuff is hard
I'm using it myself for a half a year and surprisingly - it still works
the flowers have died though as we left the flat for vacation for two weeks
What do you think - does it look as a product?
It was a journey anyway, i've learned so much, thanks Dave!
