Unless you use the information for self-testing and calibration, essentially a programmable comparator with a self-test/signal analysis mode, true.
Let's look at ATtiny404 in SOIC16, which at Mouser costs about 0.40€ apiece. It has SPI slave capability at up to 5 MHz clock, and enough pins for 8-bit parallel input. The sampling is synchronized so that all input channels are sampled at the sample SPI clock, every 8 SPI clock cycles.
So, let's say you have 20 of those. The FPGA then needs one SPI clock output, and 20 inputs. You can then theoretically sample at 5/8 MHz or 625 kS/second (one set of 8 samples per 32 clock cycles – doable, since most AVR instructions take one cycle to execute).
On the ATtiny404, the input pins would be PA4-PA7 and PB0-PB3, so a sample cycle consists of two GPIO port byte reads, two ANDIs (AND with immediate), and one OR; and a write to the SPI output register; or six cycles or so. In Master mode (so the FPGA would need to handle 40 input data and 40 input clock lines), the maximum SPI clock is 10 MHz, so the sample rate could reach 1.25 MHz, or 16 clock cycles per sample byte. It should be doable, although might need a tight assembly loop with all interrupts except start/stop signal line disabled for a continuous sampling run.
If OP needs only 250 kS/second, that's a data rate of 40 Mbits/s; quite doable. (Even
a simple USB test on Teensy 4.0 can do 200 Mbits/s; much more if one uses USB bulk transfers instead of the tty layer. With Teensies, the problem is getting the 160 digital inputs read in time – maybe if one used a bunch of 74HC4067's with all sharing the four address/selector bits?)
