Some more background info:
The EUT was never designed to meet any EMC standard. although it was designed with "best practice" it was also designed to be lowest cost and simplest to manufacture. The original use did not require any EMC compliance. (think plastic enclosure, 2 layer pcb, minimal i/o filtering etc)
As is the way of the world, things change, and there is now a requirement to use this device, with the least changes possible, in a MIL spec environment that meets the full MIL spec EMC limits! Yes, yes, i know how stupid that sounds, but bear with me here!
So, the device was tested (in a certified test chamber to MIL limits) and, no surprises, failed miserably!
What i am trying to do here is to give the customer my best estimate of what it would take to make this device (or more accurately a version of it) meet the MIL specs, with the minimum changes possible.
So, what i plan to do is to test the device in stages, ie enable / disable various bits of the h/w on the pcb (like the dc:dc, or the CAN buses etc) and to enable/disable various bit of code and processor resource. The idea is to cheaply, and quickly get an idea of the relative contribution of each component to the overall emissions level.
Of course, the results aren't going to be accurate in any way, but should give an idea of where we need to focus our changes!
So, using the metal box (with all it's reflections etc), mounting the EUT in it in a fixed position, relative to the antenna, i can run simple tests (like run the processor off a 9v battery and not the DC:DC etc) and get an idea of the relative contributions. I can also try "bodges" to the pcb to attempt to attenuate / modifiy the RF energy being emitted. The primary aim will be REPEATABILITY, and not accuracy.
Ultimately, the device WILL have to be relatively extensively re-designed, but if i can get at least a road-map for what needs to change and what brings the biggest improvements, then we will have saved a huge amount of time and effort before we get to the point of an official re-test
And whilst the idea of standing in a field to do these tests sounds nice, the British Summer (ie RAIN!) makes than somewhat non-practical (be nicer in Sydney ;-)
So, back to the original question, what antenna for 30Mhz to 300Mhz, that is cheap, and fits in a small box? I'm happy to make/bodgeup something if that is the best option?
