Author Topic: Low EMI 802.3bt PoE GbE PSE (Power supply)  (Read 460 times)
Offline larry42Topic starter
« on: February 15, 2021, 02:48:32 pm »
Hi! Anyone have tips for the best (w.r.t. lowest EMI) 60W+ (IEEE 802.3bt) PoE supply that is capable of Gigabit data for an industrial project.
Input power ideally 230Vac, metal shielding if possible for RJ-45 shield termination.
Edit: I want to buy off the shelf - no time to design one (and way too expensive w.r.t design time / testing / production qty).
« Last Edit: February 16, 2021, 06:49:43 am by larry42 »
If you have an animated GIF in your avatar or signature then I reserve the right to think you're a dolt.
Offline KT88
Re: Low EMI 802.3bt PoE GbE PSE (Power supply)
« Reply #1 on: February 15, 2021, 09:32:19 pm »
I guess you are looking for the PSE side of POE...
Here is a good starting point that I'm aware of: https://www.analog.com/en/search.html?q=IEEE%20802.3bt
Cheers
Andreas
« Reply #2 on: February 16, 2021, 06:48:34 am »
Thanks - but I want to buy COTS, not build (I'm already designing the rest of the system - no time for yet another design)
