The inter-winding capacitance of the inductor probably only becomes significant for the >1MHz harmonics where it can form a high-pass filter with the ESL of the caps, probably only noticeable if any resonances crop up, otherwise as you say it'll just give you a "floor" to the filter. Both L and C parasitics should be derivable from datasheet specs to make a vague prediction about the freq and Q, but of course highly dependent on layout.
Yes, layout is important. We have a separate power supply board that is providing a switcher regulated voltage, 7.5V and the linear regs are local to the control board. The control board has a number of ADC that sample slowly, but some signals come in at rather low levels. So I want to over do the noise mitigation rather than have to figure out where the noise is coming from later. The inductor data sheet measures parameters at 2.5 MHz, Q of 22, SRF 12 MHz. The switching circuit is nominally 0.5 MHz. Bourns SRU1048-220Y
Lossy ferrite helps keep "unexpected" resonances damped as does a little "real" resistance (if you have some overhead to tolerate voltage drop).
4 terminal SMT feedthrough caps have very nice HF performance so avoid a lot of the ESL issues to begin. But all that depends whether or not your circuit is actually sensitive to the HF stuff.
I'm not certain the HF noise will be important. We also are pumping amps into a brushed DC motor with PWM around 20 kHz. It has honkin' caps on the power rail and with the higher switching frequency we only see around 1 amp of current change during the PWM cycle. But it is still going to make a bunch of EMI.
There are some nice "all in one" power supply filters with the L's and C's combined, but usually geared toward the >10MHz stuff, I guess they're more about complying to standards than targeting specific problems... again depends on your frequencies.
I simed a filter with a ferrite and the 22 uH inductor with several caps. It has resonances but nothing that is a problem. They largely went away when I added a bit of series resistance in the AC source along with a bit of capacitance since it's coming to the board over a cable. The guy designing the switcher seems to have used less input capacitance than the data sheet suggests... STRONGLY! I'll have to say something to him about that.
If you are interested here is my simulation file. The power board uses the 22 uH coil in the switcher, so I started with that. 47 uF is about as high as reasonable in a ceramic cap without the price going up and being harder to get. I could go with a higher inductance coil easily enough. The DC current will be under 500 mA. This family of coils offers up to 220 uH handling that current.
Pwr_Filter.asc (2.29 kB - downloaded 32 times.)
