I forgot to add, what its suppose to do
- Programmable battery discharge analyser
- Analyses batteries 1V to 15V
- Discharges 0-2500mA (about 10mA resolution)
- Programmable termination by voltage, time, capacity, or dV/dt.
- Logging of data (capacity, voltage etc) to SD card, to CSV file
- Uses Arduino libraries for easy modification of firmware by hobbyists
- Spare I/O ports broken out so users can add custom features
- USB port access (via FT232RL chip), can be left empty if no USB required
- TTL-UART terminals for serial interface (when built without USB)
- Discharge in constant current, constant resistance, constant power modes
- Internal resistance test (by multiple constant current discharge steps)
- 16x2 LCD display showing current status
- 4-way key pad navigation
- Stand-alone operation, no need to connect to computer
- Can be powered by USB or external DC jack
- Calibration via serial port terminal
- MOSFET mounted externally, using appropriate heatsink for battery voltage and current discharge. This is so the user can customise their own mounting options.
