I am building a sensor and I need some help finding a part.
The sensor measures the phase difference between two signals. I then intended to convert that phase difference to an analog voltage by low pass filtering it. HOWEVER, because the phase difference is measured with an XOR gate (due to power requirements) the upper and lower voltage limits are not well defined. The solution I have come up with is to use either a MOSFET or JFET to act as a pass transistor between the low pass filter and a 2.5V reference. This is the hard part.
Because I need to maintain the accuracy of the sensor at greater than 1%, the voltage error going into the ADC must be less than 1mV. This means the noise and voltage drop across the FET must be as low as possible. This seemed like a good time to use a JFET.
My requirements are that the JFET is being driven with a 42KHz signal that varies between 0 and 3.3V. The reference voltage is 2.5V, I will probably end up buffering this with an op-amp. I found this part:
http://www.newark.com/vishay-siliconix/sst201-t1-e3/n-channel-jfet-40v-to-236/dp/06J8328 and this:
http://www.farnell.com/datasheets/910015.pdf but I don't think these will due the job due to the variance in the gate source turn off voltage.
Any help is appreciated, ranging from finding a part for me to pointing me to a website where they deal with this kind of thing. Thanks.
