Author Topic: d  (Read 3370 times)
aeharding
  • Guest
d
« on: September 28, 2015, 11:32:16 pm »
d
« Last Edit: March 29, 2023, 09:47:00 pm by aeharding »
Offline alexanderbrevig
  • Country: no
  • Musician, developer and EE hobbyist
    • alexanderbrevig.com
Re: My first board design. Feedback appreciated!
« Reply #1 on: September 28, 2015, 11:40:06 pm »
Welcome!
After a rough glance it seems to me you'll need a bettery actually connected (and regulator enabled in order for you to use the barometric sensor. Is this intended?
Also, I would not cut out decoupling capactiros for the AVCC and VCC lines. Be sure to place capacitors close to the pins for best performance :)
Offline jwm_
    • Not A Number
« Reply #2 on: September 29, 2015, 02:46:36 am »
Have you checked the quiesent current of your buck-boost regulator/minimum load? Some can be quite voracious. I recently ran into one with a 20ma standby current independent of load. And to think I originally added it in to improve battery life, trading losing half a ma via a linear regulator for 20ma continuous draw. doh.
Offline ralphd
    • Nerd Ralph
« Reply #3 on: September 29, 2015, 03:17:20 am »
I'd go with a 662k ldo to reduce board space and save cost.  If the barometic sensor can take 4.2V then drop the regulator.  Or run directly from a LiFePO4 battery.
Try driving the piezo directly; you may get enough volume and then can drop the transistor.
If your code size is not large you could save a bit by using an ATmega8a.
Is the 10-pin header ICSP? The 6-pin version would save some more board space.
Lastly, if the barometric sensor needs less than 5mA, you could run everything off a CR2032.
Unthinking respect for authority is the greatest enemy of truth. Einstein
Offline microbug
  • Electronics Enthusiast
« Reply #4 on: September 29, 2015, 07:04:19 am »
Step 0: use KiCad (or anything else but Eagle).
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
« Reply #5 on: September 29, 2015, 02:22:14 pm »
Quick scan:
Only one terminal of SL1 is connected? Also the pad right next to it is unconnected.
There are a number of holes that seem to serve no purpose?
[2c]
Arduino Template Library | Zalt Z80 Computer
Wrong code should not compile!
