who are you to judge what i like or dont like! though, i like how much they've put an effort on that video! and the heli! i hope they have the contingency plan as i've mentioned above, coz thats 5D (and the lens) is one heck of a "rock"! if its out of RF or mech failure
ps: contact Karl! he'll buy one of those and ya! thats cool, i can use the idea to get some money out of our cinematograhpy here.
it has failsafes in place for loss of rf. there is no flybar on the heli so that means it has to be electronically stabilized. you could switch off the transmitter and it will level itself out and hover in one spot until rf is reconnected or the batteries run out. LOTS of time/skillz to properly set-up.
not much you can do about mechanical failure after the fact. motor or esc failure is recoverable as these will autorotate just like a full size heli. lots you can do preventative to reduce the chances of failure. use quality fasteners, everything metal to metal HAS to be locktite'd, attention to cable routing, proper receiver placement, routine rebuilds. all the same sorts of stuff they do with full size helicopters.
in fact i already have that in mind, but just with smaller camera for surveillance purpose. but there is no strong reason for me to do that project
check out the
808 camcorder. HD doesn't get much cheaper / lighter.
hd hero is a popular lightweight camcorder
nope not done fpv, need the proper equipment for that
i've got the equipment! just lack the skillz
