Author Topic: My TO-3 switcher (buck converter)  (Read 38938 times)
Offline AF6LJ
Re: My TO-3 switcher (buck converter)
« Reply #50 on: September 30, 2015, 03:52:09 am »
This is one fo the best things I have seen come along in a long time.
I am also following. Great
Thanks, it looks good but the fatal flaw is that now that the input side needs less current, the voltage on the smoothing capacitors rises and they are running close to their rated voltage. Don't know how great that is for 30 year old electrolytics. So the lifetime I might gain by running cooler I'll lose by running those capacitors too close to their rated voltage.
New electrolytics wouldn't be such a problem, the old ones, I wouldn't be comfortable running them close to their rated voltage unless they had been run there all the time.
Sue AF6LJ
Offline ez24
  • L.D.A.
« Reply #51 on: September 30, 2015, 04:21:47 am »
Wow, time flies.
Thought you ended up at Batteriser - they may need you
Offline Alex EisenhutTopic starter
  • Place text here.
« Reply #52 on: September 30, 2015, 11:51:41 pm »
Wow, time flies.
LOL I only do buck converters
Offline AF6LJ
« Reply #53 on: October 01, 2015, 12:03:15 am »
Wow, time flies.
Those are very cool; if you should decide to sell them please let us know.
Sue AF6LJ
