MyElecParts v1.70 is now available.
https://myelecparts.hu/Linux users will be pleased to know that the PostgreSQL database engine is now supported by the program. Alternatively, if you only want to use the program for searching, database-less operation is now officially supported. This can be selected in the config file. See also the installation guide page on the website.
A minimum quantity can be set for each item; if stock falls below this level, the program will alert you, allowing you to see what needs to be restocked...
Editing inventory quantities is now easier, and the quantity field can now be adjusted using the + and - buttons with either the mouse or the keyboard. You can also increase or decrease the quantity by ten using the Page Down and Page Up keys.
A frustrating bug related to scrolling through combo boxes has finally been fixed.
Full list:
• Database: Add support for PostgreSQL database
• Database: Add support for working without database (Search only)
• Parts: Add Min. stock level for part parameters
• Parts and Storage locations: Show low stock warning
• Parts and Storage locations: Improve stock level edit
• Parts and Storage locations: Extended filtering
• Meta search: Update Datasheet4U source
• Bugfix: Fix combobox scrolling issue
• Small buxfixes
