Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Simulating a key press
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Simulating a key press (Read 1466 times)
ganaps2
Newbie
Country:
on:
May 28, 2017, 04:13:21 am »
I have a system that has membrane switches with contact pads on PCB connected to the microcontroller in a matrix fashion. Need to simulate the key press without the actual switches from an external microcontroller. Any idea of how to do this?
Logged
Paul Moir
Frequent Contributor
Country:
Re: Simulating a key press
Reply #1 on:
May 28, 2017, 04:19:12 am »
A bunch of opto-FETs too expensive?
Logged
Ian.M
Super Contributor
Reply #2 on:
May 28, 2017, 04:27:48 am »
That's the general approach, but if you have a common ground you can also use analog switches, and if its a regular matrix, an analog crosspoint switch can be a one-chip solution with a simple SPI interface.
Logged
KL27x
Super Contributor
Country:
Reply #3 on:
May 28, 2017, 08:22:32 pm »
Done this with keyboard... Bog standard BJT output optocouplers work fine in this case. Zero voltage drop of opto FET not necessarily needed.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
