Author Topic: ADF4360-8 PLL-VCO  (Read 1747 times)
Offline salviadorTopic starter
    • https://www.youtube.com/user/mancio92M
ADF4360-8 PLL-VCO
« on: May 23, 2016, 08:19:05 am »
I want build simple radio-microphone at band ~235.7Mhz.
I see this IC from analog device.
ADF4360-8 , have all, VCO, PLL
But my question is, How to modulate the carrier in FM ?
Offline rs20
Re: ADF4360-8 PLL-VCO
« Reply #1 on: May 23, 2016, 08:27:49 am »
I'm not sure that chip is suitable? In principle, you could couple your modulating signal into Vtune, but I think the PLL is going to get very upset and confused when it sees that the phase of the LO is totally out of whack with the REF clk.
I could very well be wrong.
Offline babysitter
  • pushing silicon at work
« Reply #2 on: May 23, 2016, 08:38:46 am »
Better don't do it ar all - I guess someone who has permission to use that range in his designs will also be able to do FM.
(The german frequency directory says military radio services only. As europe has a reasonable harmonisation going, this range will not be available to anyone else somewhere else in italy.)
I'm not a feature, I'm a bug! ARC DG3HDA
