Author Topic: DC-DC Switching regulator, 12v -> 5v and 3.3v  (Read 3260 times)
Offline JaspaJamiTopic starter
    • Susijarvi
« on: November 01, 2018, 03:22:49 pm »
Hello
Im looking for a switching dc-dc regulator. Input 12vdc, and two outputs: 5v and 3.3v. If it would be about 1000mA for 3.3v and 500mA for 5v that for sure should be enough. I think it can go quite much lower also from that. In i would like it to be as little extra components as possible. Any idea where i should try to find this kind of?
At the moment best one is maybe TPS5438x: http://www.ti.com/lit/ds/symlink/tps54386.pdf
But that one needs quite a mount of extra components also.
Offline t1d
Re: DC-DC Switching regulator, 12v -> 5v and 3.3v
« Reply #1 on: November 01, 2018, 03:41:06 pm »
I did a quick search one Ebay and did not see a dual unit. But, I would think that something being designed for an Arduino, on a bread board, might be dual. Otherwise, use a pre-made converter to drop to 5v and add a small 3v3 circuit, to that... That would just be a 3.3v regulator and a couple of caps... Or two pre-made converters, 5v and 3v3. These buck converters are dirt cheap, on Ebay.
« Last Edit: November 01, 2018, 03:44:02 pm by t1d »
    • Susijarvi
« Reply #2 on: November 01, 2018, 03:53:28 pm »
Trying to find good quality component that i can put on a production PCB. Amounts are not big ones so price is not so huge deal ( i mean if it cost 2€ or 6€, doesn't matter much)
Offline mariush
« Reply #3 on: November 01, 2018, 04:14:21 pm »
What's your budget?
Check MP2364 : https://www.monolithicpower.com/pub/media/document/MP2364_r1.6.pdf
1.4 Mhz switching frequency so you can use smaller inductors compared to that TPS chip, up to 1.5A per output, around 90% efficient etc
If you want really few components there's uModule parts from Linear, like LTM4622 with integrated inductors and everything... you just need a bunch of ceramic caps and resistors to set the output voltages ... but it's potentially pain in the ass BGA package and expensive (7$ in quantity): https://www.digikey.com/product-detail/en/linear-technology-analog-devices/LTM4622IY/LTM4622IY-ND/6181727
Some other food for thought
Such a dual output chip as you can see will have around 90% efficiency ... so 3.3v at 1A = 3300mW and 5v at 0.5A = 2500mW , so 5800mW ...at 90% efficiency you're looking at ~ 6500mW power consumption
If heat is not an issue, You could go for a cheaper 5v 1.5A+ switching regulator with higher efficiency and then use a LDO for 5v to 3.3v ... the LDO would obviously dissipate 1.7w of heat at 1A but that's doable in a big package... if it's MAX 1000mA , or if you have enough space then it's doable... and especially if it's for some arduino where you'd power from a 12v adapter and not batteries...
So for example you could use a 0.5$ AP3513 IC which will still be at least 90% efficient at 2A output  and at 5v 1.5A you're looking at  7500mW at 90%, or around 8300mW ... so really less than 2w extra... but the LDO only needs a ceramic capacitor on the output.
For example, an AZ1084 is less than 0.5$: https://www.digikey.com/product-detail/en/diodes-incorporated/AZ1084CD-3.3TRG1/AZ1084CD-3.3TRG1DICT-ND/4505193
« Last Edit: November 01, 2018, 06:07:10 pm by mariush »
Offline BFX
  • Country: sk
« Reply #4 on: November 01, 2018, 04:29:10 pm »
If you need only quick solution try this
https://www.ebay.com/itm/LM2596-4-Way-Multiple-Output-Switching-Power-Supply-Module-Board-3-3V-5V-12V-ADJ-/272914677919
otherwise TI part you mentioned is better with little bit of effort to design an build custom solution.
« Last Edit: November 01, 2018, 04:31:13 pm by BFX »
Offline mbest
    • Susijarvi
« Reply #6 on: November 01, 2018, 06:50:39 pm »
What's your budget?
Not planned exactly but this whole device is going to be about 100€ in parts, and whole project where this is going is 25 000€. I personally dont care if power supply parts are 1€ or 10€. Easy to manufacture, reliability are important ones. And it need to survive vibrations.
    • Susijarvi
« Reply #7 on: November 01, 2018, 06:51:46 pm »
Ok for demo use, but now im looking best solution for the final product.
Online SiliconWizard
« Reply #8 on: November 01, 2018, 07:27:58 pm »
LTC3622
The following users thanked this post: JaspaJami
Offline mariush
« Reply #9 on: November 01, 2018, 08:17:53 pm »
Yeah, so budget doesn't really seem to be a issue.
How about pcb space, are you constrained in some ways? how about vertical height? How important is ease of repairability etc?
Would it be more convenient to go with something that would allow for cheaper single layer pcbs?
For example, you have DIP8 ICs like Sanken NR8887 which would allow you to use through hole regulator, inductor and maybe a couple of electrolytic capacitors on top and then use surface mount ceramics on the bottom , or you could go completely through hole for both voltages.
Offline thm_w
  • Non-expert
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #11 on: November 02, 2018, 03:02:16 am »
I have been using TPS563200 for a while. That is a single buck chip though, but very little additional components needed.
    • Susijarvi
« Reply #12 on: November 02, 2018, 12:33:28 pm »
PCP space is not much of an issue but vertical height is. Lets say 10mm from the board starts to be near maximum.
Repair... most likely if problems whole board will be changes (about half price from whole unit bacause display is easy to remove).
PCB is going to be double sided, but thru hole is not problem at all. Anyway board is going to be combination of thru hole and smd:s
    • Susijarvi
« Reply #13 on: November 02, 2018, 12:36:10 pm »
« Last Edit: November 02, 2018, 12:52:38 pm by JaspaJami »
