Thanks guys! I will go through the two recommended sites to see if I can get an idea of how to work with these motors.
If I may, how would you get started with utilizing this motor? The 1st motor has 6 wires. I think 1st two are AC 110V to mains, the other 4 are control wires. Would u use an off the shelf motor driver or would u make ur own driver for it?
Thanks a bunch!
