I'd like to make micro-reflow device for hobby, and the most difficult is to invent how to mount MCH heater on PCB and protect PCB from heating. Of cause, solution should be simple & easy to repeat by anyone.
First attempt was to use "chineese aerohel" from aliexpress. It's not convenient material (too many dust), and insulation is far from ideal. Also, it causes too slow cooldown.
Second attempt was to use air space and reflector. Since bottom convection is very low, we should mostly care about IR waves.
Heater sits on cone bolts in brass insets. Physical contact is very small. Base PCB is covered with "acrylic glass" film for bathrooms
Better, but still not enougth. On the way - additional cover of heater bottom with reflective paint (i'm waiting until paint dries, but preliminary result is very impressive). Then, will try to make separate reflective surfacebetween PCB and MCH.
Question 1.Do you have ideas how to mount MCH on PCB with good thermal insulation and low height?
Question 2.Since i need equal temperature on all surface, about 10mm of plate from each side become useless (checked by thermal imager). Only 30x30mm left. Not bad, but i'd like to improve.
Idea is to attach Panasonic PGS sheet on top. Can you advice glue for that? Ideally, with up to 400C operating temperature, available on aliexpress or ebay. If that's impossible - up to 300C.
