Author Topic: Using SCR's as diode's - reverse blocking voltage  (Read 1082 times)
Offline adamcordTopic starter
    • Personal Website
« on: February 12, 2020, 04:13:07 pm »
In a project I'm working on, I'm thinking of using some beefy SCR's as diodes by tying the anode to the gate (a practice which is usually kosher). I want to use these SCR's due to their high blocking voltage and high current ratings. But since the Gate would be shorted to the Anode, I'd eliminate one of the P-N junctions that might otherwise be there to block the reverse voltage, leaving only one P-N junction, right?
So my question is: Does shorting gate to anode on an SCR lower it's reverse blocking capability? (I guess similarly, what if my gate driver conducts between gate-anode during the reverse voltage condition? Again, would this pose a risk of reverse breakdown?)
Offline schmitt trigger
  • Country: mx
Re: Using SCR's as diode's - reverse blocking voltage
« Reply #1 on: February 12, 2020, 04:38:56 pm »
I randomly checked the very first power SCR that I found a Vishay VS-111RKI120PBF. This is a 110 amp device.
Its data sheet indicates a VDRM/VRRM of 1200 volts, yet its maximum peak gate voltage is only rated between 20 volt and -10 volts.
Offline Zero999
  • 0999
« Reply #2 on: February 12, 2020, 04:39:59 pm »
Dumb question: why not use a diode?
To answer the original question. SCRs can normally block the same reverse voltage as their off voltage rating. The only issue is the gate typically has a maximum reverse voltage rating of around 5V. Connect a small diode with a high enough reverse voltage rating in series with the gate and a high value resistor (100k to 1M) between the gate and cathode.
You should use a diode, if you don't need a switch. It's much cheaper and easier.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: February 12, 2020, 04:40:53 pm »
G-K has a low reverse breakdown voltage, like BJT B-E (and for the same reasons).
IIRC, there are some SCRs made that way, with high breakdown on both terminals; I forget what special application they serve though.  Or maybe it's what a TRIAC is internally, of course pasted together with its complement so the device switches AC without much concern over drive magnitude or sign.
Seven Transistor Labs, LLC
The following users thanked this post: adamcord
Offline wraper
  • Country: lv
« Reply #4 on: February 12, 2020, 04:55:20 pm »
You should first have tried to measure G-K resistance with multimeter and find that it conducts in both directions with tens to hundreds of Ohm resistance.
Offline wraper
  • Country: lv
« Reply #5 on: February 12, 2020, 04:56:27 pm »
Around 0V to be exact, it's simply conductive both ways.
Offline Zero999
  • 0999
« Reply #6 on: February 12, 2020, 06:16:35 pm »
It depends on the SCR. K-G is a diode connection. In small, sensitive gate SCRs it should measure the same as a diode, using a multimeter. Larger non-sensitive gate SCRs have a gate-cathode resistor built-in.
Offline wraper
  • Country: lv
« Reply #7 on: February 12, 2020, 08:12:28 pm »
It's not a built-in resistor, it's an intrinsic feature of SCR. Small SCR may have this resistance on higher side but it's still there.  And this resistance may easily vary 5+ times times within single part number (and so does gate sensitivity).
« Last Edit: February 12, 2020, 10:18:51 pm by wraper »
Offline NiHaoMike
    • Facebook Page
« Reply #8 on: February 13, 2020, 12:16:31 am »
I'm assuming he has the SCR lying around but not any large diodes and that it's for a temporary application. In that case, add a series diode and resistor combination from anode to gate to trigger it.
Offline Circlotron
« Reply #9 on: February 13, 2020, 12:33:59 am »
That resistor in series with the diode should be something like 10-50 ohms . The value is not critical, just that this lower value makes sure the SCR turns on before the forward voltage gets too high, and the on-stage voltage drop does not give too high a continuous gate current like it would if there was no resistor at all.
