Actually, we want to use the development board of the SoC with USB and Ethernet connector. So, I kindly expect that the SoC to be suggested should have development board with USB 2.0/3.0 and Ethernet connector.
V3s?
Does it have development board?.If yes, could you share?. Also, is there anything similar to Raspberry Pi 3 ( ARM A53)?
How cheap are you looking for? There's the Raspberry Pi and similar which have graphics capability, as well as router chips that do not have graphics.
First, we looked at Raspberry Pi 3 (ARM A53 processor) development board. Since it does not have Ethernet on its development board, we could not go with it. So, similar to Raspberry Pi 3. SoC without graphics capability is fine.
Thanks and Regards,
Muthu
