Author Topic: Design Help required! Metal Oxide Varistor - in-circuit health Monitoring  (Read 510 times)
Offline aju11Topic starter
  • Country: in
We have some applications (single/Three AC and DC) which have several MOVs connected in common mode (i.e. Line to Earth).
We wish to monitor the health these MOVs and report the status over a data link (like RS485/232).
Intension here is to predict the MOV failure event and take action before actual MOV failure occurs.
I came across iTMOV series from Little fuse. But is it the only way?
Can we monitor standard MOVs and GDTs?
Online coppercone2
Re: Design Help required! Metal Oxide Varistor - in-circuit health Monitoring
« Reply #1 on: February 20, 2022, 08:04:19 pm »
its a leakage test circuit, they are put into whole home surge protection systems. MOV increases leakage as it gets worn. I don't know the circuit though. Basically a light that turns on when it gets outside of specs.
