Ran into an issue as well that I have fixed. Noise was getting bad on the clock input, causing erroneous signal to the chip, even if I just put my hand close to the floating lead connected to the pin. I coupled the pin to ground using a 6.3v, 10uF tantalum capacitor, and a discharge resistor connected to ground. The positive of the capacitor is connected to the pin and resistor, while the negative is grounded. Simple ESI filter.
Turns out I don’t have the Darlington arrays like I thought, but instead just some LM3046N transistor arrays. Those could have leakage and isolation issues so I’m doubting their use. So for now I’m using simple emitter-biased 2n2222A NPN transistors to drive the LEDs.
Yes.
"Here is the sequence I am going for: " Only when he pushes the button!
There are three jellybean LEDs (red, green and blue) and one color fading RGB LED.
The sequence is to switch to a different LED. Not to change the LED's color.
The RGB LEDs im using are like regular LEDs, these just have integrated circuitry that drives the colour changing effect with the internal diodes. It has the same anode and cathode as regular LEDs.
He only has one of these. What he is calling the RGB LED.
Again, the other three LEDs are standard red, green and blue ones.
I have decided to use standard 4-pin common cathode RGB LEDs for this project because they take less space than three standard LEDs. However, for the colour changing RGB LED, I have to use a separate LED with integrated circuitry. In the prototype, I’m using four separate LEDs representing each colour for now just as placeholders. When it comes down to the actual PCB assembly, I will be using the more compact convex RGB LEDs.
Clarifying: The FINAL PRODUCT will have a few pairs of LEDs: Each pair has one STANDARD RGB LED, and one COLOUR CHANGING RGB LED. When I press a button, it will turn on or off certain LEDs in a sequence. That sequence is red, green, blue, colour changing RGB, and off.
The reason I don’t just make a circuit to make the standard RGB LED change colours is because that takes more power. If I didn’t have any power constraints, I would omit the integrated colour-changing LED and just use the one standard RGB LED and just build a circuit to make it change colours when the RGB setting is on.
