Electronics => Projects, Designs, and Technical Stuff => Topic started by: Logan on September 14, 2021, 01:04:32 pm
Hi guys.
Anyone knows what type is this connector? Are there any IPS panel can work on this?
It seems have 32 pins, but are all 32 pin connectors compatible in protocol?
Thanks.
Measure the contact pitch, this one looks like 0.5mm, but it can be also 0.4 or 0.635mm.
Also, there are top or bottom contact option, check which one is yours.
Thanks.
What protocol? Please give a link. There is no requirement that all the tracks in a cable be connected.
The type of connector used does not indicate anything about the type of interface, there is no standard.
surely not always the same protocol or the same pinout, the only way to know is to find the lcd part number and or finding the specs of the driver chip : graphical ot text generator / driver chip if the lcd doesn't come with it ...
FFC/FPC connector
I took more photos of the driver board(1,2) and a mark on back of LCD(3).
Are there any IPS replacement panel for this connector/protocol?
