Hey thanks for the reply. We are trying to get certified for ia, Group IIB gases.
The 12 V is actually the output of a boost converter module, with 3x Zener diodes on the output in case the regulator faults. The 12 V output is used to power external sensors; we want the output capacitance minimised to be compatible with a wide range of sensors, so I guess we'll have to bump up the package size of the capacitor with a lower DC bias.
I do have another query, which is regarding an RF output of a modem that connects to an external antenna. The modem is not IS certified, but the max RF output power is 250 mW which is well below the 3.5 W limit of Group IIB according to IEC 60079-0, and has no internal voltage enhancing circuitry.
My question is under a fault condition, do we have to assume that the input VCC to the modem will pass through to the RF output? So let's say it will pass through; the manufacturer told us the sum of capacitances is 18 uF, and sum of inductances is 22 uH on the modem. The input VCC is clamped at 5 V with 2 uH and 86 uF capacitance in the worst case, so we have V=5V, C=104uF, L=24uH. Because we have a combined inductance + capacitance circuit, we have to used the universal output characteristic curves from Annex G. But Figure G.3a) the curve only show limits up to 10 uF capacitance and only for an inductance of 0.15mH. How can we prove our worst case parameters won't ignite a spark? I haven't seen any way to interpolate the curves to different inductance/capacitance values from my research.
Sorry for the wall of text, but I wanted to be as descriptive as possible. Cheers for your help.
