Author Topic: Need help with amplifier  (Read 1677 times)
Offline laejfTopic starter
« on: October 25, 2019, 04:59:00 pm »
I'm making an amplifier using the TPA3123 class D amplifier IC (http://www.ti.com/lit/ds/symlink/tpa3123d2.pdf) and I'm using it in a bridge tied configuration. The recommended circuit of the TPA3123 (Figure 1) and my circuit (Figure 2) can be seen below. I have used a bit different values in the output filter but those are the recommended values for a 4 Ohm load as seen in the datasheet.
My problem is that when connecting the input I get a very low volume on the output regardless what the gain is set to. But when I tried connecting both of my input channels into LCH and grounding RCH, the volume is normal.
Does anyone have any idea what could cause this?
Thanks
Figure 1: Recommended circuit
Figure2: My circuit
Offline themadhippy
Re: Need help with amplifier
« Reply #1 on: October 25, 2019, 05:08:42 pm »
In bridge mode your using both half's of the amp to make 1 more powerfull amplifier instead of a less powerfull 2 channel amp.If you look at the top circuit the input and outputs are marked as + and - not left and right.
« Reply #2 on: October 25, 2019, 05:19:24 pm »
I see, then how should I connect my source with a left and right channel?
Offline StillTrying
  • Country: Broken Britain
« Reply #3 on: October 25, 2019, 05:47:52 pm »
AFAICT In BTL mode you only have 1 power channel and have to use the +/- (L/R) inputs as 1 differential input channel, = one has to be inverted phase.
« Last Edit: October 25, 2019, 05:49:51 pm by StillTrying »
« Reply #4 on: October 25, 2019, 06:14:01 pm »
What's the go-to way of doing that?
Online Kleinstein
« Reply #5 on: October 25, 2019, 06:19:47 pm »
In bridge tied mode one would need a second amplifier chip for the other channel. Otherwise add both signals together to create a good old mono signal and use the inverted signal für the - input.
In bridge mode the amplifiers see effectively half the speaker impedance.  So with 4 ohms speakers the amplifiers see only an effective 2 Ohms load and would thus need more current and less voltage.
So with 4 Ohms speakers better use non bridge tied mode.
« Reply #6 on: October 25, 2019, 06:34:01 pm »
Which inverted signal do you mean?
Offline StillTrying
« Reply #7 on: October 25, 2019, 07:03:02 pm »
I'm not sure what you're expecting, BTL gives 2X the voltage and 2X the current through the speaker so 4X the power, but you have to make one of the +/- (L/R) inputs inverted yourself.
I'm no expert in audio, I've used simple 1 transistor to get 2 out of phase signals in the past.
https://www.electronics-tutorials.ws/amplifier/phase-splitter.html
« Reply #8 on: October 25, 2019, 08:50:43 pm »
Thank you. I'll try to figure it out
Online Kleinstein
« Reply #9 on: October 25, 2019, 09:13:04 pm »
The signal inverter is normally done with an OP-amp. The simple transistor tends to cause distortion and poor PSRR and thus hum.
One would get 4 times the power only if the amplifiers can deliver twice the current. More normal one would use speakers with twice the impedance and than get 2 times the power from 2 amplifiers.
Offline Audioguru again
« Reply #10 on: October 26, 2019, 04:49:23 pm »
I agree that the datasheet does not show BTL driving a 4 ohms speaker because with the much higher power then the IC will melt.
It can drive a 4 ohm speaker is the supply voltage is reduced enough (try 14V) for the maximum low distortion output to be a little less than 25W.
« Reply #11 on: October 28, 2019, 09:26:32 pm »
I have not thought about that, thanks for clarifying!
