Author Topic: Silly tread  (Read 25688 times)
Offline tggzzz
Re: Silly tread
« Reply #100 on: December 01, 2018, 08:31:40 pm »
barely based drinks like beer do not mix well with grape based drinks like wine.
Barley. Spull chuckers are onederful.
Offline ebastler
Re: Silly tread
« Reply #101 on: December 02, 2018, 01:20:19 pm »
It looks for me what someone bully me with not sufficient "guitar" posts, since we know now that problem is not guitar
I'll try one last time to get this thread back on track, and on topic.
001, there may indeed be nothing wrong with the guitars you tried. (I.e. in a more typical environment, they may work just fine.) But in the challenging environment next to the server room, improving the shielding on the guitars and amplifier, and maybe selecting a particular type of pickup for the guitars, my be the only realistic solution to the interference problem. More likely than not, you can't change things at the source (assuming the signal comes from the servers).
So, unless your friend wants to find a different room for practice, the questions others have asked about the guitar(s) and their shielding are valid. -- On the plus side, the servers will probably not mind your friend's acoustic noise much; so this practice room has its merits.  ;)
Why don't you get back to troubleshooting, and restore the thread's title to something more meaningful?
The following users thanked this post: Richard Crowley
Offline 001Topic starter
  • Country: aq
Re: Silly tread
« Reply #102 on: December 02, 2018, 02:44:51 pm »
I drunk a little yet
The idea is to find problem direction and add steel plate to wall or to build a Faradey cell
« Last Edit: December 02, 2018, 02:46:53 pm by 001 »
Offline SiliconWizard
Re: Silly tread
« Reply #103 on: December 02, 2018, 05:10:52 pm »
Taking  measures to add some shielding to your equipment will be much easier than trying to shield the whole room.  :-DD
Note: It's probably best to try and avoid drinking while playing with electricity. Just saying... ::)
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Silly tread
« Reply #104 on: December 02, 2018, 05:13:24 pm »
i am a firm beleiver in judicious natural selection.
Offline Cyberdragon
Re: Silly tread
« Reply #105 on: December 02, 2018, 05:39:55 pm »
Tell that to Photonicinduction. ;D
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline Simon
  • Global Moderator
Re: Silly tread
« Reply #106 on: December 02, 2018, 05:43:07 pm »
Sure, he is obviously smart enough to pass natural selection. He is accepted into the sensible sector of humanity - did i really just say that?
  • Country: aq
Re: Silly tread
« Reply #107 on: December 03, 2018, 08:51:57 am »
I am a firm beleiver in judicious natural selection.
What hell with You? I`m 65 now and drink beer every day.
Does anybody has experience with Faradey cell at 5kHz?
« Last Edit: December 03, 2018, 08:54:14 am by 001 »
Offline coppercone2
  • √Y√... 📎
Re: Silly tread
« Reply #108 on: December 05, 2018, 04:51:37 am »
most real labs I have seen feature a no liquids policy unless its dangerous ass hydraulics that can spray you with water connected to 3 phase from 50 feet away. Thats fine but no water bottles or beer.  :palm:
open enclosures and stuff were fine with all the cooling water,but for god sakes no beer or water bottles.  :clap:
working in a big puddle on the floor with exposed mains in a chassis on a metal cart? no worries. not even about the alligator clips. no one will bat an eye. weird unknown chemicals come pouring out of a tank when you open it.. who gives a fuck. dust from god knows where? (probably from los alamos plutonium cabinet), who cares
 Possibility of alcohol: serious fucking situation.
ahh workplace logic, easier to try to understand black hole surface physics then figure out the insane policies out (trick, you cant figure them out, their literally insane).
« Last Edit: December 05, 2018, 04:58:57 am by coppercone2 »
The following users thanked this post: 001
  • Country: aq
Re: Silly tread
« Reply #109 on: December 05, 2018, 07:10:14 am »
Offline TurboTom
Re: Silly tread
« Reply #110 on: December 05, 2018, 02:52:00 pm »
IIRC, the OP mentioned AC / cooling devices somehwere. The 5kHz can well be the PWM frequency of a variable frequency drive (VFD), powering a substantial induction motor. If not properly filtered and no screened cables are used, this noise may radiate anywhere. Will be difficult to eliminate it at the guitar/amp's site, rather have a look at the source and see what you can achieve there...
Offline Wan Huang Luo
  • 顽谎骆 from the Shenzhen Market
Re: Silly tread
« Reply #111 on: December 05, 2018, 06:40:53 pm »
This thread is full of  :-BROKE and  :popcorn:
Offline Gyro
Re: Silly tread
« Reply #112 on: December 05, 2018, 09:54:55 pm »
Agreed. With the OP content deleted, it is indeed very silly to continue it. Somebody up there should have locked it by now.
Best Regards, Chris
