Author Topic: Need help with identification  (Read 701 times)
Offline MGaddictTopic starter
« on: May 21, 2022, 04:15:09 am »
I recently purchased a Texas Instruments Extensa 650CD. I was told there was no hdd. What I didn't realize is, Acer, who actually designed and manufactured it, used a caddy and this is the connector between the 2.5" IDE 44pin HD, and the computer.
I've found all the technical specs and diagrams. (Thank you TI.) So if I can find the female connector, I can pin this out and make an adapter.
Unfortunately, I have been searching for hours and can't find anything that looks anything like this. Any help/suggestions appreciated.
__________________________________________
Sent from a P4 HT still in daily use. Old != Useless
Offline Fraser
Re: Need help with identification
« Reply #1 on: May 21, 2022, 06:34:10 am »
In your picture I can just see the letters “HRS” on the front right face of ten connector. As I suspected when I first saw it, this is a Hirose branded connector and may still be in production.
https://www.hirose.com/en/product/#
Offline Fraser
« Reply #2 on: May 21, 2022, 06:50:15 am »
Xx range look similar but I suspect is the modern version with different pitch and dimensions. You will just need to hunt through the various Hirose multi pin connectors found with Google. That is what I do.
DX40 image attached
Offline mclute0
  • Somnium aut moriar!
« Reply #3 on: May 21, 2022, 06:52:47 am »
looks a lot like https://docs.rs-online.com/186e/0900766b80e6dc32.pdf
like an old school SCIS 40 pin male connector or a mini-Centronics 40.
hard to judge scale from your picture.
cheap laptop makers of the 20th century loved to repurpose connectors to fit their needs.
I think the TI 650cd also shared some parts with a number of laptops sold under the NCR brand, but I will not swear to it.
Offline Fraser
« Reply #4 on: May 21, 2022, 06:55:01 am »
« Last Edit: May 21, 2022, 06:57:52 am by Fraser »
Offline Fraser
« Reply #5 on: May 21, 2022, 07:04:25 am »
« Last Edit: May 21, 2022, 07:09:58 am by Fraser »
The following users thanked this post: MGaddict
« Reply #6 on: May 21, 2022, 05:30:06 pm »
I find it funny. Looking at the specs sheet, and taking a micrometer to this, this does look correct, however, I have no clue how you got there. It says RCT-6A24 on the top. As low res as that picture was, how you noticed the HRS logo is beyond me. Thank you so much. I had to get a magnifying glass to see it. Great catch. The RCT was completely throwing me off.
Now that I have the right thing, I'll hopefully find a 40 pin female connector. I see exactly what I want on that spec sheet. So I can search for it. Again, I am just beyond shocked you found that. Thank you.
Offline Fraser
« Reply #7 on: May 21, 2022, 07:11:05 pm »
No worries. Pleased to assist.
I am used to looking for connector ID’s and know where to look on the part. The brain is good at interpreting partial characters when you are used to various makers marks  :) Finding the exact connector series took more effort as I had to look through several hundred HRS connectors via Google searches.
Fraser
« Last Edit: May 21, 2022, 08:47:04 pm by Fraser »
