Author Topic: Quick circuit: low voltage inrush limiter (USB?)  (Read 2493 times)
Offline c4757pTopic starter
  • adieu
« on: November 23, 2015, 06:15:51 pm »
A lot of the circuits I see floating around online for doing inrush current limiting, perhaps for a finicky interface like USB, are either overcomplicated or stupid. Some even in manufacturers' app notes don't really work. Thought I'd write up and share a circuit I've been using a lot lately that works about perfectly for this:
FET Inrush Protection
It's fairly simple, so I'm sure I'm not the first to do it quite like this, but hopefully I can post this and bring up the SNR on this particular topic a bit ;D
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Quick circuit: low voltage inrush limiter (USB?)
« Reply #1 on: November 23, 2015, 08:28:36 pm »
Well, one of those USB power switch thingers does everything: active current limit (if imprecise), hiccup or latched fault mode, thermal limit, the works.
Neither of the discrete examples are actually "current limiting", they just fake it by being slow.  I don't think FTDI has much in the way of analog engineers, and EDN...what did you expect? ;D
Seven Transistor Labs, LLC
  • adieu
« Reply #2 on: November 23, 2015, 08:42:16 pm »
Fair enough :)
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #3 on: November 23, 2015, 09:03:50 pm »
I've found the MIC20XX family to look promising. Not expensive and they have a lot of different configs.
Unfortunately, I never got around to use one since the specs of the project did change.
  • adieu
« Reply #4 on: November 23, 2015, 09:23:40 pm »
Yeah, that's a nice-looking chip - definitely will put that on my list :)
Offline Howardlong
« Reply #5 on: November 23, 2015, 09:35:21 pm »
Depending on what you're doing, the USB3751-1 might be a solution.
This offers a ton of features particularly for USB devices with rechargeable batteries, including charging port identification and capabilities, under- and over-voltage protection and ESD protection. It also offers 100mA current limit until configured otherwise.
They're not cheap ($0.44 1ku) but depending on the application, once you've added up the cost of all the other paraphernalia using discrete devices, it might be an economically viable solution.
Offline BravoV
  • +++ ATH1
« Reply #6 on: November 23, 2015, 11:49:45 pm »
Perfect for my need with the excess of fets lying around, and appreciate the writing, thanks !  :-+
Offline dadler
« Reply #7 on: November 24, 2015, 12:19:36 am »
Clever, and very professionally presented. Archived for later reference. Thanks!  :-+
