OP, I see a couple mistakes in your circuit, and unfortunately your PCB.
The two LED's, C1 should connect to BATT(-) not to BATT(+). edit: solar cell as well. The circuit won't operate.
Your inductor value is huge at 1mH, it is more typically 33-100uH.
D1 1N4148 loses more voltage than a Schottky part like 1N5817, so the 1N4148 is not as efficient.
