If you are doing transparencies, the inkjet is the way to go (around here, anyway) - it seems capable of 0.15mm or even better accuracy.
I think you missed the point of what I was doing. I was trying to differentiate between the accuracy of the laser printer vs the paper/transparency. I am not doing transparencies, they were chosen as a stable medium (PET) that allows easy overlay and comparison and would test the laser printer accuracy with minimal distortion due to the media.
The result is that the laser printer on the test page provided, has a maximum error of around 0.25mm over the whole page. The 0.8mm errors you reported, I am pretty sure, unless I have an exceptional machine, are due to paper shrinkage/expansion. The inkjets are better because they don't have the shrinkage/expansion issues of the laser. They might also provide blacker and more consistent blacks, I don't know as I don't have one.
Anyway, it was more a matter of curiosity on my part, but it also points to the outcome, that if transfer papers were more thermally stable, the results of the laser would be better, or use an inkjet which doesn't have the issue.
