Author Topic: Need OffTheShelf Hysteretic LED driver  (Read 927 times)
Offline ocset
« on: April 22, 2018, 09:54:01 am »
Hello,
We are doing a 6W Constant off time controlled Buckboost LED driver…
(schematic and LTspice simulation attached).
Vin = 18-137.5VDC
VLEDs = 45V
Power = 6W
Constant off time control (off time = 3.5us)
No electrolytic capacitors allowed (no large films either)
Note: It actually has to work down to Vin = 8V , but only at 1.2W for that case.  :blah:
The wide Vin range means constant off time control is needed for control. The problem is, there are virtually no offtheshelf constant-off-time controllers available. (except the HV9910B, but that has no internal error amplifier, and only a weak gate drive).
Therefore, we had to use a “hacked” UCC28C43 controller.  :-/O
The problem is that the controller, with all the auxiliary components needed with it,  take up a lot of space, and  space is very constrained. The PCB is only 22mm by 200mm. We are only allowed  double sided PCB, no more layers. Driver components go on the bottom, LEDs on top.
The biggest problem, is that our lack of space means that we can’t fit much input capacitance on the PCB.   :scared: We only have 2uF of ceramic input capacitance, -that’s all we could fit on.  :palm:  The result is that there is fairly significant ripple in the input current. This may fail EMC, (though we havent had the standard limits given to us yet).
Another point is that in some products,  several of these 6W PCBs will be used together…..and as you know, this means that there will be beat frequencies as they interact with each other. This could well occur at the resonant frequency of the EMC input filter, and that would mean unwanted resonance there.
What we really need is a  “dual threshold hysteretic controller”.  -By that I mean a controller which allows one to set a maximum and minimum threshold for  power inductor current….(and these would be  varied ‘on the fly’ by a micro)…we could then simply get a micro to read the actual LED current, and then simply increment the thresholds gradually until the desired LED current was achieved.
Do you know if such a controller exists?  :-//
 8)
Offline Zero999
  • 0999
Re: Need OffTheShelf Hysteretic LED driver
« Reply #1 on: April 24, 2018, 04:09:55 pm »
It's a shame the PCB is so narrow. You could have used a wide input range DC:DC converter, such as muRata RUW15SL12C or RUW15SL24C (these will work from 16V to 160V), to give a nice regulated 12V or 24V supply, then run your LED driver off that.
https://www.digikey.co.uk/product-detail/en/murata-power-solutions-inc/RUW15SL24C/811-2784-ND/3723979
https://www.digikey.co.uk/product-detail/en/murata-power-solutions-inc/RUW15SL12C/811-2783-ND/3723978
The following users thanked this post: ocset
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: April 24, 2018, 04:21:34 pm »
I have a solution which regrettably is too elaborate to fit in this margin...
Seven Transistor Labs, LLC
Offline Zero999
  • 0999
