Hello,
i have a vintage bit of kit that i'd love to test out but i can't find the pinout or specs:
An Oscillatek 10.000MHz OCXO
P/N 282376B
model 8032
My unit also has a Scientific-Atlanta PN: 285603
It has the 10Mhz coax output and a 7-pin connector, 2 of those have soldered and shrink-wrapped cables that are cut, i guess those are the power supply but i have no idea the voltage needed either(i could start cranking up until i get an output)
This OCXO was pulled from scientific-atlanta satcom datalink systems (the ooold ones that worked at RS232 speeds and were 3U high rack units, plus big 2m diameter antennas with ORUs)
All i can find is ebay listings of it and it appears the company changed names as well to VI-OLATHE, but absolutely no info on its performance or pinout(and i don't have the gear to really characterize the stability/phase noise/phase stability of this)
