Yep, the 6R was just a guess, you might be confusing me with someone who knows what they're doing.
Here I've changed the loads to 2R, and modulated them all with a 1kHz sine to give near max power which seems to be about 32W. (Hold the 'ALT' key while over the load and click to see the Watts.)
The peak volts across the loads is +-11V.
The peak current through the loads and inductors is +-5.5A, which might be enough to saturate the inductors ,I dunno.
The Watts in the loads at the peaks are 58 Watts.
How useful this is I don't know, but by looking at the current through the load, the 400KHz, 2.2uH, 1uF version looks the noisiest.
