Author Topic: Should I Use an Opamp for Low Frequencies  (Read 30940 times)
Online fourfathom
Re: Should I Use an Opamp for Low Frequencies
« Reply #25 on: February 22, 2022, 08:07:34 pm »
Applying the same voltage to the "top" of the potentiometer and the "ref" of the ADC is a common way to make a ratiometric measurement, which does not rely (much) on the stability of the reference voltage.
Agree, and I did mention this technique up-thread.  I'm curious to learn what the actual circuit looks like.
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
Offline Bassman59
  • Yes, I do this for a living
« Reply #26 on: February 22, 2022, 08:14:02 pm »
Funny, I just designed a thing that reads a bunch of pots and that's exactly what I did.
Offline aw_rw1Topic starter
« Reply #27 on: February 23, 2022, 04:36:20 pm »
With a 10 or 12 bits ADC and a 2-3 V FS range there is no need to worry about the amplifier.
:-+ I was thinking this too.
The voltage that you want to measure comes from the wiper of a potentiometer.  What is the source of the voltage that is connected to the top of the pot?
I used a Sorensen lab power supply. Then I started using batteries. The battery's voltages were clean when I read voltages from the stack. Though the voltages off a POT were noisy. So what could I do about this? I am seeing numbers between 670-685 out of 1023. Average of ten of these numbers is 676.92.
You may want to look at a ratiometric design.
Interesting, I may do this.
« Reply #28 on: February 23, 2022, 04:40:58 pm »
I looked at some voltages around the system with the ADC. Then I put back the wiper on the ADC. The noise went away. So the noise most had been a contact issue.
« Reply #29 on: February 23, 2022, 04:43:32 pm »
Actually, the noise was coming from my laptop's charger. I plugged my charger. Then the noise came back.
