Hello Fellow members,
I am putting up the circuit given by dave in his video series on Lab power supply using LT3080. However, during testing i found that the current limit was not working .. the output of the current limit op-amp was not able to pull down the set pin of the LT3080 to ground. I am attaching the circuit herewith, whenever the current limit is reached the output voltage isnt falling down to zero as it should be and the voltage at point A ( Please see the attached figure) moves to -2 V instead of hitting the positive rail +12V , hence the transistor remains OFF. Kindly see the problem and suggest the problems .
Thank You,
