I used to know all this years ago... how to work out the flux density, and choose a material which doesn't saturate, but I have long forgotten!
It needs to be good with a 13V peak square wave, 500Hz.
So we have 13V across 8mH for 1ms, which from v = L (di/dt) yields 1.625A. A quick hack in LTspice confirms this, for the first 5 cycles. I had a lot of trouble generating a square wave from -13V to +13V
so I am not sure what the current waveform will look like when you switch to -13V when the current flowing is still 1.625A; I suspect it will not ever exceed 1.625A later though. With a 13V peak sinewave (a predefined function) it looked to be just under 1A, but all positive which is obviously BS.
The bit I have forgotten is how to calculate the flux density in the core. I would prefer the whole thing to be something the size of an RM10 core
https://www.farnell.com/datasheets/528671.pdfIn 3C95 material you have 5500nH/T^2.
A toroid would have less stray flux, and again there is a vast choice. I have a bag of these from many years ago
https://www.tme.eu/gb/details/tn16_9.6-3f3/ring-ferrites/ferroxcube/tn16-9-6-6-3-3f3/which with 83 turns would achieve 8mH.
What I don't get is how much current this will carry. 83 turns at 1.6A is 132 AT which sounds an awful lot. I thus suspect I will need a bigger core, probably iron.
Looking on Ebay for ready made stuff, 10mH, I see e.g.
https://www.ebay.co.uk/itm/115852064002but I am instinctively damn sure that won't carry the current.
Another option is some toroidal transformer, and ignore the existing winding and put more turns on it. Ebay is full of vintage transformers but most are pretty big.
I was going to wind the TN16 with some turns and see what it does. I have an HP 3314 pulse generator and a power amp which can output 9V peak.
The 8mH needs to be +/- 0.3mH. It was determined experimentally using this amazing thing
https://www.ebay.co.uk/itm/224101042113but that obviously contains massive magnetics - it weighs about 1kg.
I also have an LCR meter.
I'd be grateful for any suggestions.
