I just love the marketing fiction on the first page of Mosfet datasheets, 350A from a D2PAK, yea, right!
At least the bipolar stuff sometimes has useful things like SOA curves (But usually only at 25 degrees C case temp).
Personally I favour TO3P, but at no more then about 80W and 5A or so per device, makes cooling actually possible.
The elephant in the room with TO3 is thermal expansion issues, you generally do not want to solder them straight to a PCB (In fact IIRC one of the IPC standards has quite a lot to say about this).
Some sort of sleeve from the likes of mill-max might be suitable, at those currents but I would be taking a long hard look at your design assumptions.
Regards, Dan.
