Hello
I have a board carrying a power section and digital control (functionally it is a sort of inverter). Despite the fact that I kept nets separate and galvanic insulation, in some conditions I have interference problems, due to high currents (10A) and high voltage switching (the output is going up to 2000V).
I think I need to separate more the two sections, and I am looking at some alternative to the optocouplers. For example, I might place the components on two different boards and then use some insulated coupling to transmit the signals. I do not need speed, just 7-8 lines (4 in one and 4 in the other direction). Is there any commercial component that does the task? I mean something like fiber coupler. I have no experience on that.
