Author Topic: Never draw a power PCB like this  (Read 2637 times)
Offline China NewBoyTopic starter
  • Country: cn
« on: November 05, 2019, 07:31:57 am »
 Result:
Boom ,The strip blow up, and i made a black mark on the floor,the air switch of the outlet was pop ,half of the PCB  turn to black .
fortunatly, i didnt hurt myself.
 what cause it:
the L and N on my PCB are too close, and when the power line being pulled and drag back incidentally,the wire loose,and a piece of wire cross through the L N .
 i really learn a lesson from it.
(the floor and PCB have been cleaned,the mark still is on the floor)
« Last Edit: November 10, 2019, 05:53:10 am by China NewBoy »
Offline capt bullshot
Re: Never draw a power PCB like this
« Reply #1 on: November 05, 2019, 08:30:29 am »
Nothing wrong with that, everyone (in electronics) has to make this kind of experience at least once in his life / career
The following users thanked this post: China NewBoy
Offline Miti
« Reply #2 on: November 05, 2019, 11:22:58 am »
It gives you that feeling of awareness and respect for electricity that you didn’t have before.  :-DD
Fear does not stop death, it stops life.
Offline AndyC_772
« Reply #3 on: November 05, 2019, 03:14:41 pm »
I've seen marks very like that on the inside of a metal chassis, underneath the PSU. The PSU had live wires soldered through holes, which hadn't been properly cropped close to the PCB surface, so it only took a mild knock (or possibly a modest voltage spike) to create an arc from PSU to chassis.
Top tip, it may be worth making PCB stand-offs a little longer than you think is strictly needed, and/or putting an insulator under the PSU.
  • Country: cn
« Reply #4 on: November 05, 2019, 03:32:02 pm »
;) thanks for your tip ;)
Offline Twoflower
« Reply #5 on: November 05, 2019, 04:02:51 pm »
Probably note strictly required, but I'm a fan of screw-terminals. At least for higher voltages and/or currents. If used properly they prevent shorts, look nicer and allow to replace the cable. Especially if you later put the PCB in a case you don't need to re-solder it.
And you should add enough spacing not only between P and N but also between anything that is connected to mains and low voltage circuits that can be touched in any way.
Offline DBecker
« Reply #6 on: November 05, 2019, 06:00:49 pm »
You should "never" solder stranded wires directly to a circuit board.  And if you do (because it's easy and inexpensive) make certain that the wires both have strain relief and can't flex (even with strain relief they may flex).  High voltage wires breaking off can be deadly.  High current wires can start a fire.
The following users thanked this post: janoc, tooki
Offline H.O
« Reply #7 on: November 05, 2019, 07:25:27 pm »
Only somewhat related but anway…
A few years ago I was testing a DC-servo drive. The motor, a fairly beefy one rated for 19A continous at 130VDC, was clamped to the bench with a big C-clamp. The drive was making full speed positioning moves back and forth continously and I was checking for an issue with the encoder feedback that had previously resulted in lost position. Everything was working fine so I left it running and went inside to do some other things. When I came back some time later I found the motor on the floor and the fuse blown. The motor survived but the drive didn't. As the motor fell to the floor it must have yanked on the cable causing the free-hanging pigtail of the Cable shield to short out to one of the motor terminals on the drive.
Here are a couple of photos.
  • Country: cn
« Reply #8 on: November 06, 2019, 12:02:20 am »
WOW... i can smell it..
Offline nife
« Reply #9 on: November 08, 2019, 12:22:46 am »
The distance between the conductor pads seems adequate/legal (although it is hard to measure mm with eye sight). It is likely the (legally required) strain relief which is the real culprit.
Offline EEEnthusiast
  • Country: in
  • RF boards, Precision Analog, Carpentry
    • https://www.zscircuits.in/
« Reply #10 on: November 08, 2019, 02:14:36 am »
If you have any ground pours near those contacts, I would recommend to move them apart and have no ground fills near the L & N entry points. The same goes for wherever these high voltage lines are routed.
Making products for IOT
Offline bjbb
« Reply #11 on: November 08, 2019, 07:53:14 pm »
No problem. Compliance engineers/techs do this (on purpose) several times per week or day.
In fact, all EEs should probably spend a day watching a series of fault tests per on of the major safety standards early in your career, at least once. [Can be done in Asia or Europe labs, but NRTL and SCC labs in North America will not allow 'spectators'].
Offline v8dave
  • Country: id
« Reply #12 on: November 09, 2019, 04:45:45 am »
It does look like there is a ground pour and that is likely where the short occurred. The spacing looks OK to me too but that ground pour is a big no no around high voltage areas.
Make a cutout in the ground pour next time and also use slots in the PCB to increase the creepage distance if you really must have high voltage AC on your PCB.
  • Country: cn
« Reply #13 on: November 10, 2019, 05:47:17 am »
that's right
