Hi everyone
I have a project that I am working on and I could use some input.I have a zenith transoceanic model G-500 tube radio i built a battery for it out of 60 1.5v AA cells and 6 1.5 v D-cells this gives me 90v B+ voltage and 9v a+ voltage I think my current draw on the B+ side is 25 or 30 milliamps I was wondering if a dc to dc converter would work i would still use batters for my input voltage and for my A+ side,
After i watched Dave's video on DC to DC converters I thought this is what I needed. I searched eBay and found a 95 Volt DC to DC converter, it has voltage adjustment of 60 to 95 volts DC. I contacted the vender and she said it would not work in my application. Below is the data on the converter, my question is why won’t it work? I can supply the input voltage needed and the output is within my requirements 90 volt around 30 milliamps max Am i missing something? If this won’t work then what do you think i need to do, build one or do they make something like this for retail? I have looked and I can’t find any 90Volt DC power supplies. This converter was all i found that boosted DC to DC at 90 volts. I did find a AC to DC battery eliminators on a old radio museum web site but i would like to run this thing off of batteries. It has a AC to DC built in power supply, it works great on AC, so i wouldn’t need the battery eliminator. The search title for this thing on eBay is :DC 10-32V 12V to DC 60-95V Boost Step-Up Converter Adjustable Charging Module. [/b][/i] Any input or advice would be greatly appreciated
Thank You lomack
Module Properties: non-isolated step-up module (BOOST)
Input voltage: DC 10-32V
Output voltage: DC 60-95V continuously adjustable
Output Current: 2A (MAX)
Input Current: 16A (MAX) (Please enhance heat dissipation over 10A)
Output power: natural cooling 70W (MAX), to enhance heat dissipation 100W (MAX) actual power
Conversion efficiency: 85% typical
Output Ripple: 2% (MAX) 20M Bandwidth
Operating temperature: Industrial grade (-40 ? to +85 ?) (ambient temperature exceeds 40 degrees, lower power use, or to enhance heat dissipation)
Full load temperature rise: 45 ?
No-load current: Typical 35mA
Load regulation: ± 0.5%
Voltage regulation: ± 0.5%
Dynamic response speed: 5% 200uS
Short circuit protection: None (Please enter install fuse or protective circuit)
Dimensions: 65 * 47 * 23.5mm
Applications:
DIY an adjustable output vehicle power supply. Connecting to a 12V power supply, the output voltage is 60-95V continuously adjustable. But please be sure that the output voltage can not be lower than the input voltage
Boost charger
Power for your electronic devices
Solar battery charger for electric vehicles
