Author Topic: NEW, SUPER-EFFICIENT DESOLDERING METHOD. Yeah, right...  (Read 5795 times)
Offline CaveMannDaveTopic starter
  • Upside the Downside
« on: November 04, 2019, 10:33:10 pm »
 : :Everybody, what do you think about THIS monumental FAIL!
    Can you say Heavy Metal Toxicity?
How about trace and joint contamination?
https://youtu.be/WUjxtrK1xTM
Who wants to employ this technique  on customer  repairs?
Cheers,
Dave
Some say that I'm a wise man. Some think that I'm a fool.   It doesn't matter either way,  I'll be a wise man's fool.  For the lesson lies in learning, And by teaching, I'll be taught,  There's nothing hidden anywhere, It's all there to be sought...
(Procol Harum, "In Held Twas In I")
Offline KaneTW
Re: NEW, SUPER-EFFICIENT DESOLDERING METHOD. Yeah, right...
« Reply #1 on: November 04, 2019, 10:41:36 pm »
Mercury in liquid form isn't particularly dangerous. The problem here is residual mercury causing joint failure down the line, and potential RoHS/whatever issues.
E: oh, he takes a soldering iron to it. As long as the fumes are sucked off (fume hood or similar) it should be fine. Mercury vapors are not something you should breathe. But soldering in a fume hood sounds like a giant headache, and I doubt that dude's doing it.
« Last Edit: November 04, 2019, 10:43:27 pm by KaneTW »
Offline tooki
« Reply #2 on: November 04, 2019, 10:52:31 pm »
Fucking hell, soldering with mercury is right up there among dumb ideas. And then using a toothbrush to clean off the dross... hello ESD damage. (Solvents don’t prevent ESD damage. In fact, I saw a report about a chemical plant explosion caused by static buildup in alcohol, caused by the alcohol flow.)
The following users thanked this post: hans, SilverSolder
« Reply #3 on: November 04, 2019, 11:08:36 pm »
Kane, Thanks for seconding my objections to this method.  ;Dni
Tookie: i hadn't considered the static discharge aspect (goodbye expensive, perhaps irreplaceable device),  but was appalled by little QuickSilver particles flying around the area.
Did "he" actually recommend gasoline (petrol) for cleanup, or was that another video?
Cheers,
Dave
Offline DaJMasta
    • medpants.com
« Reply #4 on: November 04, 2019, 11:19:04 pm »
That seems incredibly stupid.... and raw mercury may actually be harder to find and more expensive in the US than a cheap hot air gun....  and while the liquid may not be dangerous to have around, it's very dangerous to handle, so the residue on the iron, the splatters from flux boiling, the residue on the board.... all of it would be effectively hazardous waste not suitable for a landfill.
Mercury's boiling point is about 350C, too, so it doesn't take much extra heat from your iron before you're breathing it even with a decent flow fume hood.  They overlay "safe soldering" on the video like they're trying to reassure themselves...... the right equipment is so inexpensive, don't throw your health away handling and trying to solder with mercury.
Offline not1xor1
« Reply #5 on: November 05, 2019, 06:45:23 am »
what about galinstan or other similar eutectic alloys?
The following users thanked this post: BrianHG
Online magic
« Reply #6 on: November 05, 2019, 07:46:15 am »
Indeed, I'm not going to waste my time watching it but from the reaction here I gather that the guy has never heard of products like QuikChip.
That being said, I just carefully use a low power heatgun on the rare occasion I need do desolder some large SMD crap.
Offline xavier60
« Reply #7 on: November 05, 2019, 09:06:50 am »
I got some  Wood's metal off ebay to then find that Wood's metal contains toxic Cadmium. For the short time I used it, I found it very good for removing SMD parts at reduced temperature.
But I don't think I was sent pure Wood's metal anyway because it becomes a paste at about 100°C and liquid about 130°C.
Looking for low melt solder on ebay, I found this, https://www.ebay.com.au/itm/Special-130-degree-C-low-melt-temperature-solder-wire-dia-0-5mm-4-meter-length/142018652365?hash=item2110f8a8cd:g:oLsAAOSwpdpVWp9U
Which also has Cadmium.
Rose's metal appears to be safe if the supplies available on ebay can be trusted to be non-contaminated.
I don't see why an alloy needs to be eutectic for the application.
https://www.ebay.com.au/itm/75g-Alloy-Rose-Roses-metal-Roses-metal-Lead-Bismuth-Tin-alloy/183658130100?hash=item2ac2e0aab4:g:d0IAAOSwtaBcMxiK
« Last Edit: November 05, 2019, 09:10:14 am by xavier60 »
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
The following users thanked this post: vk6zgo
Offline m3vuv
« Reply #8 on: November 05, 2019, 09:53:58 am »
if ive a scrap bourd i want the ic's etc from i put it on my cooker hob give it 2 mins then invert the board and give it a bash on my worktop,never fails to get them out without damage!
Offline tooki
« Reply #9 on: November 05, 2019, 10:04:40 am »
Right? I'm sure little balls of mercury amalgam rolling around a board full of fine-pitch SMD chips is a GREAT idea!
He sure did!!
Now, using hydrocarbon solvents for PCB cleanup is totally valid — n-hexane is a fabulous (if highly neurotoxic) solvent, and many flux removers are blends of alcohols and hydrocarbons. But vehicle gasoline is full of additives, and I'm sure it's not good as a cleaner. Knowing this guy, he'd probably recommend using leaded gas, too...
I suppose it's possible that in whatever country he's in, petrol could also refer to some other kind of hydrocarbon substance which could be more suited. (For example, here in Switzerland, "Petrol" in the grocery store is lamp fuel.)
Offline tooki
« Reply #10 on: November 05, 2019, 10:05:30 am »
Oh, it's time well spent.
Online coromonadalix
« Reply #11 on: November 05, 2019, 10:26:02 am »
stupid ways to remove a chip,   use an hot air station thats all   pfffff
You overheat the board, and you may damage the pcb traces  etc ....   not all pcb are well made .......
« Last Edit: November 05, 2019, 10:27:34 am by coromonadalix »
Offline Miti
« Reply #12 on: November 05, 2019, 10:58:00 am »
Mercury creates vapours at room temperature. Watch this:
https://youtu.be/aSO3ykbaiM8
Now imagine that you buy a house where a dumbfuck like this applied his “safe” technique all day long in his basement lab. Or you take your TV to him to repair. You bring it back full of mercury droplets. Then after few months you wonder what’s with this crushing fatigue that all your family feels.
Idiots at work !
Fear does not stop death, it stops life.
The following users thanked this post: janoc, tooki, BrianHG
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #13 on: November 05, 2019, 11:26:18 am »
Offline tooki
« Reply #14 on: November 05, 2019, 12:14:48 pm »
LOL, what an idiot! https://en.wikipedia.org/wiki/Mercury_poisoning
And getting dumber, no doubt, from the chronic mercury poisoning.
This is what he replied to someone's safety concern in the comments:
"It is also used in the preparation of pharmaceuticals, if it does not go into the mouth, there is no harm in it . I'm using it for many years for desoldering. it is not harmful."
I mean, 180 degrees backwards. (Elemental mercury ingestion is pretty much harmless, but the vapors definitely are not.)
  • Country: tr
« Reply #15 on: November 05, 2019, 01:45:21 pm »
Yet another one: https://en.wikipedia.org/wiki/Erethism
and in some extreme cases with prolonged exposure to mercury vapors, delirium, personality changes and memory loss
Offline DBecker
« Reply #16 on: November 05, 2019, 06:09:25 pm »
Addressing only this very narrow point..
I don't see any value in an eutectic alloy.  Your goal is to dissolve the existing solder, which will immediately move the resulting alloy away from the eutectic point.  Unless I'm missing some effect, the ideal would be alloy that moves closer to the eutectic point when mixed with the existing solder.
Offline janoc
« Reply #17 on: November 05, 2019, 07:00:06 pm »
I have actually reported this video to Youtube under the "Dangerous acts" category. They better take it down before some idiot (and there are plenty of them in the comments!) decides to emulate this fool.
The following users thanked this post: hans, thinkfat
Offline tooki
« Reply #18 on: November 05, 2019, 07:19:23 pm »
I did the same thing earlier today. It’s totally reckless. I also took the liberty of using copy-and-paste to reply to many of the comments with a warning.
Offline Shock
« Reply #19 on: November 05, 2019, 07:23:00 pm »
I think he is using Gallium, you can see it solidify as it puts it on the top of the IC. I would think Mercury would be more liquid. If it's pure Gallium its boiling point is 2400C. Not sure how much of an effect it would have but it's corrosive to other metals so you would want to remove it thoroughly.
The following users thanked this post: CaveMannDave
Online magic
« Reply #20 on: November 05, 2019, 07:52:59 pm »
Knowing YT they will kindly ignore your report or if they don't, the video will be reuploaded next day together with a short commentary about New World Order taking down videos to sell more hot air stations.
You do it because you know they don't care about your opinion :P
Offline tooki
« Reply #21 on: November 05, 2019, 08:16:09 pm »
At the end of the video he says it’s mercury and calls it “harmless”.
Offline boffin
« Reply #22 on: November 05, 2019, 08:57:00 pm »
just use Chipquick
And there's an Eevblog video for that too....
Offline Shock
« Reply #23 on: November 05, 2019, 09:12:26 pm »
The second half of the video is muted for me. But as I said it doesn't look like Mercury unless it has already been turned into an alloy. Could be a Gallium Tin alloy that can melt around 25-28C. Anyway nice screwdriver tip he is using. :)
Offline janoc
« Reply #24 on: November 05, 2019, 09:25:32 pm »
It is certainly not gallium, gallium isn't liquid below 29C or so (you can see it is well liquid when he is picking it up from that tin). Unless his room was very hot, there is no way it would work like that - it would be either solid or semi-solid until heated up.
He also mentions several times in the comments it is mercury - which is apparently easy to get in India or where he is from. He mentions in the comments that it can be easily bought in stores (it is used in traditional Indian ayurveda medicine, together with lead - yay). Gallium isn't commonly sold as it has little domestic/traditional medicine uses apart from thermometers.
« Last Edit: November 05, 2019, 09:37:16 pm by janoc »
