Hi Folks, I currently am working on a triggering circuit for an application at home. I basically pulled the circuitry shown in red box from the attached image. I or-tied 5 and 6 together on the NOR gate and use ground to trigger the relay.
You should change that to a CD4093, which has a schmitt action, to ensure the transistor is never partly turned on.
My question is that this works well up to a certain resistance across ground and the inputs to the NOR gate however I would like to have more sensitivity. I would like the circuit to trigger if there was about 16 megohm between ground and the inputs.
What pullup do you use ?
A HEF4093B specs 0.1uA MAX pin leakage, which is > 60Mohms equivalent.
A 4093 will trigger at about 5.6V falling on 12V, so a 18 Meg pullup will give close to your 16M threshold.
Take extreme care with board leakage at those high resistances.
