thanks a lot CosteC for your comment
Yes i am aware of the legal limit outer case temperature for CE approval,
I just feel if they lovered the series regulator voltage 10V to 5V (200W to 100W loast at 20A)
it is realistic to be under 50C on that large outer alu frame, the thermal connection could have been at least made to transfer halve of it that way,
the Fets use a very high value source resistor, compared what we are used to from NPN solutions,
the reason is fets need more feed back voltage change, in my unit all resistors looked like same temperature,
I think it was designed for worst case spread of VGS, this means you can replace any of the fets, and it will still share correctly,
this also means we could have improved the thermal by spreading the fets,
the funny think about the transformer : one of my former co workers, contacted me, i know they got at least two similar units in their factory,
i think he will now go check if they also got the same idle power loss, they also got thermal cam to check this fast and easy.
