Can anyone suggest an isolated (>= 1kV) 5V-5V DC isolator, that can cope with almost no load, maybe down to the single-digits of mA?
I'm looking to make an RS-485 isolator. Part of that requires power supply isolation to the isolated-side MAX481 or similar chip.
While I'm normally a fan of things like the Murata NME or NKE series (e.g. NME0505SC
http://uk.farnell.com/1021456), I'm aware these things have a minimum load requirement. E.g. the 1W converter outputting 5V wants to see a minimum load of 20mA. The logic isolator (ADuM1401) says it wants 1mA per channel, so 4mA, and the MAX481 wants basically nothing as compared that. So I'm still 16mA short of the minimum load. Without that minimum load, the power isolator has a tendency to output excessive voltage.
So my options here seem to be any of
- Burn the extra load off in a big resistor. Seems a bit wasteful
- Aim at a higher output voltage and pass that through a linear regulator - e.g. 9V then 7805
- Find a DC converter with a lower minimum load requirement
The final of these three options seems the most elegant to me, but I'm not sure what products would be available there.
Can anyone recommend anything?
