Look at the front of the panel:
You see a horizontal line there with a sine symbol below. With the meters I know this means that they are suitable for AC and DC measurements. (at least according to German VDE markings)
edit: Definitions are in DIN 43 802 and VDE 0410. I think there are equivalent IEC standards available for this)
The star with the "2" in it means it has originally been insulation-tested up to 2000 V. I wouldn't bet on that with the given age
"2.5" means a total accuracy of 2.5% relative to the max value of the range (15 A).
As for the measurement principle itself, it's marked as moving iron arrangement. (it's the little coil symbol with the line in it)
So I'd expect it to even give you true RMS values.
Interestingly enough that the mounting position is not marked. I'd think it's intended to be used in a vertical panel.
If mounted horizontally, it might have wrong readings...
If you receive the meters, please post some pictures of the stickers on the side of the case.
Maybe I can tell you more based on that information.
Thilo
