Was watching my old pictures, when ran across how I fixed micro USB connector on Nokia 8800e Arte which was broken off together with two top layers of PCB. So I decided to share them. This model is charged via this connector so it needed to be rugged enough fix. When I came up with idea that I need to take a pictures of this porn
, already scratched PCB up to the third layer, desoldered vibra and soldered connector back to it's place on the internal ground layer Slodering vibra back was the last tough part because wires unsoldered from the heat nearby on the first try and I had to do half of the work again. This is my friend's phone and it still works without problems after 1 year and 4 months.
