So I have a IEC connector that lost its retention spring thing that would act as a shitty secondary ground (other then the fast on leading to lug that is bolted to chassis.
I don't know if I like a fast on for a variac (it might rumble), so I wanted a secondary ground. I thought the best way might be to take a solid copper wire, solder it to the shield of the IEC filter, then bolt that to the chassis. That way there are no DIY crimps anywhere in the secondary ground.
If I want to press a copper loop into an aluminum chassis, what is the best option? I thought to make a split galvinized bolt, bolt it to the chassis with a star washer and al-nox, then put the solid copper wire into the groove cut into the bolt and then tighten that down with another nut, rather then trying to sandwich the copper wire between the bolt and aluminum chassis.
Or I also thought to solder a copper bolt directly to the shield so it has a stud and use two ring terminals with a stranded wire, ring crimps and then use penetrating loctite to make sure the bolt does not loosen.
Has anyone ever seen a fast-on connector come loose from vibration before? I don't like how there is no good way to retain them. Normally I don't care but this is just a big variac in a box.. does anyone see a safety problem with relying on a brand name fast-on connection as the ground here? I used a good crimp tool and TE brand connector, but even if its speced properly, it seems a little wimpy for an all metal chassis.
Maybe putting some electric silicone on the end of the plastic crimp housing would act as good enough a retaining compound to make me be at ease?
This is for a 20 Amp variac, its the highest power circuit I have worked on yet DIY. I made all the ground connections by removing the paint with a dremel stainless brush, cleaning with alcohol, then wetting with al-nox and scrubbing it in with a dremel stainless brush, cleaning up the splatter around the ground point and giving it some fresh al-nox on top before bolting it down. They read very low and I would likely check the ground connection before use after I stored it for a long time.. so my main concern is that fast-on coming off during use on heavy loads because of vibration.
I also thought to drill a hole in it so I can lock it into place with a bent wire (u-clip)
