Hi everyone,
I have a circuit with a non inverting Op-Amp configuration as shown below. I apply a 0.4V ref. voltage on the non inverting input.
I am using this Op-Amp
http://ww1.microchip.com/downloads/en/DeviceDoc/20005367B.pdfI supply the Op-Amp with 1.8V
In my case Rs is a variable resistor.
This is the formula I am using to calculate the output voltage:
Vout = (Vref x Rf) / Rs +VrefThe circuit works fine for high resistor values. For example when
If Rf = 90Ω and Rs 680Ω I measure around 0.456V which is correct
If Rf = 90Ω and Rs 180Ω I measure around 0.616V which is correct
My problem is that when Rs < Rf I do not have any gain and the output voltage decrease instead of increases... For example
If Rf = 90Ω and Rs 56Ω I measure around 0.736V which is incorrect (it should be around 1.05V)
If Rf = 90Ω and Rs 33Ω I measure around 0.624V which is incorrect (it should be around 1.50V)
Rs (Ω) | Vout (V) |
680 | 0.456 |
270 | 0.536 |
180 | 0.616 |
100 | 0.768 |
82 | 0.808 |
56 | 0.736 |
33 | 0.624 |
10 | 0.512 |
As you can see for resistor values less than 80Ω (that is close to Rf) the Vout stop increasing and instead decreases
I do not have this problem for high Rf and Rs values ( in the order of kΩ).
Any advice?
Nick
