Worry about what? Track impedance at 250Hz soft-transitioned analog signal? Really no.
You should be well more worried about your grounding system on the PCB, or using the differential inputs from the ADC correctly. Otherwise, with a bad layout and a few sources of EMI you can easily reduce the effective resolution you could get from the adc to below16 bits in some extremes due to induced noise.
