Author Topic: Number of people inside a store = ?  (Read 588 times)
Offline Lucky-LukaTopic starter
« on: April 27, 2020, 08:57:44 pm »
Hi all
Do you have an idea how I can check the number of people that go inside and go outside a single door store? I need to know how many people are inside. I would like to use Arduino. It's a project related to covid19 safety measures: not more than x number of people inside a y m^2 space.
Thanks
Memento audere semper.
Offline Rerouter
Re: Number of people inside a store = ?
« Reply #1 on: April 27, 2020, 09:04:37 pm »
The usual approach is line break sensors, atleast 2 with an offset to tell direction, however unless you have a store with a forced entry and exit path and place the sensors where people do not stall, you will have to have a means of compensating for missed and extra counts.
Depending on the store may be easier to supply a staff member at the counter with an up/down click counter.
The following users thanked this post: Lucky-Luka
Offline Kleinstein
« Reply #2 on: April 28, 2020, 07:29:49 am »
The sensor may not work absolute reliable, e.g. counting legs / arms instead of people. So one would need means to correct (e.g. manually), possibly more than the natural one from negative numbers.
