Hey Everyone! Looking for a recommendation on some DC blocking capacitor to be used in a low measurement test box. I'll be used to measure low noise laser drivers, such as Wavelength Electronics WLD3343 or the Koheron CTL200. I will be using an AD797 low noise amp to boost the noise and a DC blocking cap from the laser driver load to the input of the amp.
I'm looking for an ultra low leakage cap to not only function as DC block, but to also act as my highpass filter with a cutoff frequency of 1-10Hz. I found a good app note from Jim Williams that talks about such a cap, but damn is it pricy.
https://www.analog.com/media/en/technical-documentation/application-notes/an124f.pdfIn my first attempt, I used the following cap, but only 2 in parallel:
https://www.digikey.com/en/products/detail/rubycon/16MU226MD35750/4969522?s=N4IgTCBcDaIIwDYC2BXMZkBMDMBWA7LgAwgC6AvkA This time around, I'm making a PCB with everything on it and into a metal box to hopefully get more consistent measurements as my original test set up consisted of eval boards, batteries, cables, etc etc.
At the moment, I may be sticking with the cap given above and just create a very large parallel combination to get up into the mF. Resulting in hundreds of dollars just for the caps alone.
Any recommendations/alternatives is much appreciated.
